dragula65000
- Apr 14, 2004
- 180
Here's a good one. I haven't been on in a while, but the knowledge I've gotten has helped. When I start up, it runs a little rough and have to get in gear fast before it dies. I can put the throttle all the way to WOT and it just putts along. After a little bit of messing with the throttle, I can get it to plane out and run up to 2500 RPM's. While doing that, I can burn ALOT of gas faster than I should, and while trying to accelerate it bogs, studders, and I smell fuel. I know its a fuel problem. Coils checked good, but don't have the good tools to check the rest of the ignition. Could it be bad jetting, or sticking trigger? The proper spec plugs are in. Thanks.
