  #1
Old June 6th, 2005, 07:15 AM
Hirsch Hirsch is offline
Default Pontoon not sitting level
We just purchased a 1995 Sweetwater, 20ft pontoon. It had water in the left pontoon which we took to get repaired. We put it back in the water and it doesnÂ’t sit level when stationary. The left pontoon was sitting 2 inches lower in the water than the right. Also, when you walked to the left side of the boat it would noticeably drop down, whereas, when you went to the right side the boat did not drop. We took the boat back out of the water to the welder. When rocking the boat on the trailer, you could not here any water in the pontoon. After a week at the welder, he told us that he had not observed any water leaking out and could not find any leaks with the pressure/soapy water test. He also said that pontoon boats sometimes donÂ’t sit level. So, my question is do pontoons sit that uneven? I have been on several and none of them have. Are there any other ideas as to what could be going on with this boat?Thanks
  #2
Old June 6th, 2005, 07:33 AM
DJ DJ is offline
Default Re: Pontoon not sitting level
Hirsch ,First off, how is the pontoon laid out? Fuel tank on one side? Battery? Seats, etc?
  #3
Old June 6th, 2005, 07:34 AM
Silvertip Silvertip is offline
Is there more "stuff" on the side, such as xtra batteries, water tank, fuel tank, coolers, furniture, etc. It may simply be a "load" issue.
  #4
Old June 6th, 2005, 07:44 AM
We have put nothing additional on the boat (coolers, etc). When I took the measurements, I was the only person onboard. The fuel tank (20 gallons) is full and is on the left rear. I have two batteries on the right side of the boat towards the rear as well. As far as the layout of the boat goes-- down the left side : table and 3 benches (all empty underneath) down the right side: Captains chair plus console (wrong term IÂ’m sure) and one bench (empty underneath as well). I measured fore and aft on both sides and it was 2 in lower at both ends.
  #5
Old June 6th, 2005, 07:55 AM
CATransplant's Avatar
CATransplant CATransplant is offline
That 20 gal. of fuel weighs in at about 160 lb. Does the 2" difference go away if you're standing on the right side of the boat? If so, you should be able to redistribute weight by loading heavier junk on the starboard side.
__________________
Sure...go ahead and laugh at my old aluminum boat. It's paid for!
  #6
Old June 6th, 2005, 08:07 AM
I have not checked with additional weight on the starboard side. The batteries are on that side, but don't weigh 160lbs. But would the gas at the very back of the pontoon affect the front equally? We were both out on the boat and when we sat at the table I thought our drinks would slide off. We could both move to the other side and it didn't seem to drop the pontoon further in the water like on the port side.
  #7
Old June 6th, 2005, 10:34 AM
bayman bayman is offline
Weight on one side or the other very well could be a factor.I have 2 other guesses as well:1. One of the pontoons does not have as much flotation as the other - for whatever reason.2. When weight is put on one side of the boat, the fuel is sloshing to that side of the tank, adding even more weight to that side of the boat.
  #8
Old June 6th, 2005, 10:40 AM
DJ DJ is offline
As a clarification. Flotation foam is nothing but dead weight until the boat swamps. The "bouyancy" of the toons is a matter of area, not inner flotation.I suspect you still have a leak.
  #9
Old June 6th, 2005, 12:07 PM
Right DJ - who knows if this pontoon has any foam or not. Not looking at the boat it just sounds like the area within the pontoons which is causing it to float is just not as big. The very same thing can be easily observed with an inflatable boat when one side is more inflated than the other. There may be water, sludge, water-soaked foam or whatever in the left pontoon.
  #10
Old June 6th, 2005, 01:05 PM
Interesting. I am not sure about the foam. Can the pontoons with foam be welded? Good question about there being sludge left in the pontoons. How would one go about removing sludge if that were the case?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Trailer level-boat level? Johnnielund Trailers and Towing 6 August 9th, 2005 05:40 PM
Engine been sitting Daddypolk Non-Repair Outboard Discussions 5 April 5th, 2004 06:29 PM
35' pontoon trailer for 28' pontoon???? whatsadixie Trailers and Towing 3 May 22nd, 2003 06:01 AM
sitting a bit 1bigdog1 Johnson & Evinrude Outboards 1 March 6th, 2003 05:55 AM
Boats' been sitting....What now? steve forsythe Non-Repair Outboard Discussions 5 January 10th, 2002 04:52 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
