Bigdaddyinkalamazoo
- Jul 27, 2005
- 1
I have a '85 20HP Evinrude, model# E 20EL COS, the starter bendix got stuck under the flywheel. I was able to unjamm the bedix then a few days later the bendix would not engage, but the starter had good rpms. I played with it a bit and was able to work the bedix up and down and it now functions but the bendix head (gear)is chewed up. I was told , by a friend, that I should take the bendix off and clean the shaft and lube it up. My actual questions is: How do I get the bendix off? The 11/16 nut on top is too tight and the whole starter shaft turns around. When , and if, I do get it off how and with what should I clean the shaft and wad do I lube it up with? Can I but just the bendix/kit or do I have to buy a whole new starter? Any info./input would be great. Thank you.
