Re: shift selector switch '70 evinrude needed
Are you talking about the push button switches.<br />Some can be replaced with a 3 postion toggle switch. And the other setup requires a double pole 3 position toggle switch. If neutral requires power to the shift soleinod you need the double pole. If nuetral requires no power to the shift solenoid then a regular three position toggle switch will do the trick. I have used this set-up on a couple of motors.
