Have 2005 model 175hp direct injection 2 stroke evinrude with 45 hours use and recently after use have oil leaking from motor running down leg. Is this normal?
Welcome mudcrab I wouldn't consider that normal on a new motor.Is it still under warranty? if so you should contact the dealer first to work out any repairs, otherwise you could risk voiding the warrantyPost back with any results
