  #1
Old October 17th, 2005, 05:38 PM
MAKO72 MAKO72 is offline
Default Help with 1993 70 hp evinrude "hole in tilt tube"
I recently was given a 1993 70 hp .The trim does not work because there is a hole in the port side trim tube. I cant see the hole well because it is on the left side of the tube and there is only about an inch between the tube and the rest of the assembly. I dont know if there was a screw or plug there that fell out or if it is just actually a hole. I cant feel in enough to see if there are threads in there. Anyway I was hoping you guys might have a solution for me. I was thinking maybe jb weld or try to tap it and put in a small bolt with a gasket or weld or maybe you know where I can find a used trim unit. The motor does work it just pours the fluid ou the hole. Thank you
  #2
Old October 17th, 2005, 06:17 PM
Solittle Solittle is offline
Default Re: Help with 1993 70 hp evinrude "hole in tilt tube"
Someone may jump in who knows that motor. In any case I suggest that you get the OMC shop manual. It will give you both diagrams, pictures for this and anything else that comes up.
  #3
Old October 17th, 2005, 06:35 PM
mikeyzx2 mikeyzx2 is offline
It might be where the sending unit for the trim gauge was. At least on my '77 model it is.
  #4
Old October 18th, 2005, 12:51 PM
How much pressure is going through there. thanks for any help
  #5
Old October 18th, 2005, 02:31 PM
Walker Walker is offline
You either need to post a pic are give a better detailer description. "Port side tilt tube" does nothing for me. If you are talking about a hydraulic line then there will be nothing threaded into it, its just a hole and needs replacing.If you are talking about the hydraulic cylinder then maybe. Never heard of one developing a hole.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude 40 HP "tilt assist" glacierbear Johnson & Evinrude Outboards 9 December 3rd, 2005 08:03 PM
"Quick Start" & "fast idle" questions on '97 Evinrude 11 StAugVol Johnson & Evinrude Outboards 3 April 16th, 2003 07:29 PM
6 hp Evinrude "pee hole" not "peeing" theboat Johnson & Evinrude Outboards 5 April 8th, 2003 06:33 PM
Trim tilt "screams" Evinrude 1987, 70hp Fredrik23 Johnson & Evinrude Outboards 2 March 27th, 2003 03:25 PM
Long time NOT running 62 evinrude ""help john""!! mezman Johnson & Evinrude Outboards 7 March 19th, 2002 01:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
