  #1
Old October 7th, 2005, 10:55 AM
bros250 bros250 is offline
Default Evinrude Ficht warning signal
I have a 2002 Evinrude Ficht 200 h.p. Recently while starting the engine on the water after being operated all day, the audible warning horn remained on at start without any accompanying lights on the dash. I was able to disable the horn by turning the key to the left just enough to turn off my dash power, but kept the engine on until I hightailed it home (less than 1 mile). My fuel level is good, oil level good, water pump working - but the horn remains on constant after start. I thought it might have something to do with the key ignition so I replaced that which apparently wasn't the problem.Any suggestions?Thanks all.Mike
  #2
Old October 7th, 2005, 03:07 PM
Cricket Too Cricket Too is offline
Default Re: Evinrude Ficht warning signal
I think that the constant alarm is usually for overheat and low fuel and/or oil flow. Even though you have enough fuel or oil there may be a blockage causing the alarm. I doubt it's an overheat since you said it does it even right when you first start. I'd try and find the problem before running it again, just in case you do have a fuel/oil flow problem.
  #3
Old October 7th, 2005, 04:01 PM
seahorse5 seahorse5 is offline
Your Evinrude FICHT 200 has a completely different warning system, called System Check, compared to 1995 and older motors which used a series of "beeps" to determine any problem.The SystemCheck warning horn is actually a driver, similar to a loudspeaker, that is actuated by the 4-LED SystemCheck gauge. Since no warning lites are on while the horn sounds, most likely the internals of the gauge are bad. Substitute a known good gauge to see if that fixes the problem.
  #4
Old October 7th, 2005, 04:02 PM
Thanks for the advice.. I just can't figure out why none of the warning lights stay on on the dash. They all light up on shut off during the initial start as they should.
  #5
Old October 7th, 2005, 04:04 PM
Seahorse, looks like we posted at the same time. The lights all light up initially and then go off as if no problem.
  #6
Old October 8th, 2005, 01:38 AM
That's why I'm thinking that it is a bad gauge, because the self test works, but it is the gauge that "tells" the horn when to beep and for how long.
  #7
Old October 8th, 2005, 06:06 AM
thanks for the advice seahorse
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Low Drive Oil Warning Signal timrsd Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 October 10th, 2006 11:04 PM
Oil level warning signal ToJo Mercury & Mariner Outboards 4 September 12th, 2005 08:19 PM
warning signal when having starting problems jjboor Johnson & Evinrude Outboards 2 August 5th, 2004 05:59 AM
Mercury engine warning signal billbraswell Mercury & Mariner Outboards 5 November 11th, 2003 10:31 PM
Yamaha 225 warning signal luckynaylor Yamaha & Suzuki Outboards 2 September 3rd, 2002 07:09 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
