1988 110 johnson.. The tilt would not let the motor go down so I started playing with the release ... I guess I screwed it up because not it leaks... Is there a washer in there? and how do I repair it???<br /> Thanks <br /> Steve
Re: Can I repair the manual release on my tilt trim?
Tilt the motor fully up,and brace it.Remove the circlip retaining the release valve,replace the valve,replace the circlip,top up fluid.Tilt up and down,recheck fluid level.<br /><br />DHP
