Hey guys,<br /><br />I have a 63' Evinrude. I used the wiring diagram provided here. http://mercury.walagata.com/w/chapsboy/5557180.jpg <br />Everything is to the "T". But I can't get the motor to turn over at all. The only time that I thought the motor had life, is when I jumped the starter directly. <br /><br />So my questions short of any other insights are;<br />(these are all per the diagram)<br />1)Does the SOL terminal on the ignition goes via white wire to the second terminal from the left on the solenoid.<br />2)Does one magneto wire go to the MAG terminal on the switch and the other to ground?<br />3)Does the furthest left terminal on the solenoid go via green wire to the BAT terminal on the switch.<br /><br />Hope you all can help soon. It is 12:44 pm and in the 80's. I have to get on the water today!!!!
