  #1
Old September 24th, 2005, 11:19 AM
captaingrubby captaingrubby is offline
Default Engine Sporadic After Cleaning And Adjusting Carb On 48hp SPL Evinrude
I just cleaned out my carbs with Seafoam because the idle was always rough and it had not been done in some time. Everything was good to go until I was adjusting my carbs adjustment screw to see if I could improve the idle. When using ears at home I got the idle perfect but on water testing did not go so well because as soon as you hit the gas it was instant "studdering" and it would not accelerate. On water adjustments were going pretty good... got it just right so it idled good and when I hit the gas she shot up on plane...YIPPEEEE... ..... THEN if I stopped the engine and tried it again... it would studder again for a minute or two... then blam... full power again. If I turned off and on .. same thing... every time. When I put the cover back on the engine it also had an effect on the acceleration etc. It ran better top off than on every time. Can anyone help...It's got new plugsCompression is 131 cyl 2Compression 135 cyl 1New gear lubeFresh Carb CleaningWhat would make it so sporadic? I'm thinking something is wrong with the air/fuel mix with the carbs but it's totally incosistent.Any help would be GREATLY APPRECIATED
  #2
Old September 24th, 2005, 11:36 AM
MCM MCM is offline
Default Re: Engine Sporadic After Cleaning And Adjusting Carb On 48hp SPL Evinrude
"If it ain't broke don't fix it" with that said I would hope you kept track of which adjustments you made and you should return them to their original settings. Beyond that Mr. JReeves has a great post on carb adjustments.Mike
  #3
Old September 24th, 2005, 04:54 PM
Solittle Solittle is offline
You may have an exhaust leak under the cowl with the result being the engine is not getting enough fresh air. It is sucking exhaust gas.What exactly did you do to clean the carb?
  #4
Old September 24th, 2005, 08:52 PM
All I did to clean carb was open up front airbox to expose carbs... spray seafoam at fast idle till can was gone and dat's it. Changed spark plugs right after that too which made firing easier/better. That was it I'll check to see if I can find an exaust problem. Thanks guys.
  #5
Old September 24th, 2005, 09:48 PM
MCM MCM is offline
Hi, As you said earlier everything was good to go until adjusting the carbs adjustment screw, so its got to be a fuel/air mix problem/solution, I'm not familiar with your motor so I'm not sure if this post will apply, but this link may provide starting point. http://www.iboats.com/cgi-bin/ubb/ul...=036900#000004 Good luck,Mike
  #6
Old September 25th, 2005, 07:25 AM
Goodoleboy Goodoleboy is offline
Just spraying sea foam into carb. throats only does a decarb job on engine. It does nothing to clean carbs.You will have to take carbs apart and soak with carb cleaner. And be sure to remove welch plug in order to clean under them also. Use compressed air to clear all passages. Put in new needle and seats and check floats for proper setting.Check all fuel connections from tank to carbs for air leaks.Good Luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude carb cleaning matrix29 Johnson & Evinrude Outboards 2 July 2nd, 2005 03:04 PM
adjusting carb to run smother on 78 200hp Evinrude 70wellcraftV20 Johnson & Evinrude Outboards 15 April 25th, 2005 08:46 AM
adjusting the carb on a 77 25 hp evinrude tdr9499 Johnson & Evinrude Outboards 1 December 18th, 2003 05:19 PM
83 evinrude 115hp carb cleaning help fsds123 Johnson & Evinrude Outboards 1 August 25th, 2003 09:03 AM
carb adj on 48hp Evin (1994) Benday Johnson & Evinrude Outboards 2 December 18th, 2002 02:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
