  #1
Old September 23rd, 2005, 10:17 AM
salmonjodi salmonjodi is offline
Default 1969 Evinrude 40 horse...fuel mixture
Just came upon a 40 horse Evinrude and need to know the fuel/oil mixture, if anyone can help...thanks. Previous owner not sure.
  #2
Old September 23rd, 2005, 10:28 AM
BF BF is offline
Default Re: 1969 Evinrude 40 horse...fuel mixture
50:1 it's a baaaad sign that the previous owner didn't know. You should assume it has been subjected to neglect/abuse through ignorance.
  #3
Old September 23rd, 2005, 10:33 AM
Thanks, BF. I hear you about a bad sign but he mentioned he mixed the gas the same as his chainsaw, so I figured it was either 40 or 25:1. I am hoping a little more oil is better than not enough. Thanks again.
  #4
Old September 23rd, 2005, 12:11 PM
Paul Moir Paul Moir is offline
Use TC-W3 oil, not oil for a chainsaw.Check out the Engine FAQ forum for details on how to decarb the engine. It's almost definitely due especially if aimproper oils were used.
  #5
Old September 23rd, 2005, 12:56 PM
BF BF is offline
What I meant was that since he was not aware of the oil type/ratio, my guess is that other maintenance things may have been completely ignored. Did he know to regularly change the lower unit oil? or that the water pump needs periodic servicing?To be safe, I'd assume it's been neglected (=not maintained properly), and go through all maintenance things now... then you know when it was last done. Be a shame if an old hardened impeller self destructed once the motor starts getting some use again... or if the lower unit gets wrecked 'cause there's more water than oil in it.I've saved a couple "neglectarino's" myself... well worth it, but I assumed I'd be catching up on years of maintenance and figured that into the cost when I considered buyin' them. On one I also wasn't sure if the previous owner had known enough to mix the gas properly. But compression was good so I took a chance. The gear oil had no water, but was black as tar. He'd probably never changed it. I could've parted it out for what I paid, but it turns out to be a strong runnin' 15 hp, so it ended up being a bargain.A service manual would be good.good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
9.5 johnsonsea horse age / fuel mixture Greg-b Johnson & Evinrude Outboards 2 July 2nd, 2006 05:01 PM
Johnson Sea Horse Fuel Mixture tillimrich Non-Repair Outboard Discussions 2 August 31st, 2005 04:28 PM
Johnson Sea Horse Fuel Mixture tillimrich Johnson & Evinrude Outboards 1 August 21st, 2005 06:52 PM
fuel mixture ratio for 1969 Johnson 33hp? Rotti Johnson & Evinrude Outboards 1 June 28th, 2003 02:54 PM
Fuel Mixture 1969 1.5hp Johnson RPJS Johnson & Evinrude Outboards 1 January 17th, 2003 11:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
