Starting problem
rtvh
Hello. I have a 1990 3 cyl. 60 hp evinrude on a sc 175 sea nymph. My problem is. Sometimes it starts pretty well and other times it will just crank and not start at all.I suspected the ignition switch or hoping anyway it is the problem.I haven't replaced anything yet. I did check the spark on all 3 cyl and they all spark but sometimes it will skip a cyl. or I didn't see any spark on any cyl.Any direction on this would be appreciated. Thanks
JB
Re: Starting problem
Check out Engine FAQs, rtvh.<br /><br />Let us know what you find, and good luck. :)
rtvh
Compression check 115. Engine will run great when it starts.I did notice the fuel gauge jumping to full to empty the last time it was running if this is any indication.
