Re: What year? Evinrude
Thanks for your reply. I always thought it was a 35hp.So much for trying to decode the model #.<br />As for the problem...it starts ok and idles but misfires at all speeds. It lacks power at wide open. Throtle linkage is ok, butterfly opens all the way.Fuel in the glass bowl stays at mid level, but when I pump the bulb engine rpm stay the same.If I close the choke at wide open it runs the same ,then slows down afterabout 3 seconds. Spark plugs are last years. Upper cylinder orange spark, lower blue.<br />Any help is appreciated.<br />Thanks
