Hello and thanks for this great forum!<br /><br />The engine is a 25hp 2-cylinder 2-stoke Evinrude outboard from the early eighties. <br /><br />The problem is quite simple: No spark on either plug. Only that I don't really know how to start trobleshooting. I am not even sure I understand the function of this particular ignition system enough to start pinpointing the problem.<br /><br />The ignition as I see it: <br /><br />The flywheel has two magnets on its perimeter 180deg apart. Under the flywheel is one coil that has two wires, one combination of two coils has three wires and one white object that has a vertical strip of metal has two wires.<br /><br />The set of three wires go to a socket on the engine cowling. The other 2 + 2 wires go to another black well insulated object<br />(coil?) and from there one orange wire to #1 hi-volt coil, the other orange wire to #2 hi-volt coil and a black wire though the kill switch to the frame/ground.<br /><br />When I measured voltage between the wires coming from under the flywheel and frame all readings were zero. The black coil under the flywheel gave about 540ohms and the white object with the metal strip gave 37ohms. The comb. of two coils gave 0 ohms. I've tested the continuity of all related wires and they seem to be ok. <br /><br />I have not yet tested the continuity of the plug hats and hi-volt wires.<br /><br />I would be very very greatful on any advice and tips for this problem. I have a feeling that it can't be anything too complex but I just need to know what is what and what kind of readings should I get from different components.<br /><br />Thanks already!
