HELP<br /><br />MY 2002 JOHNSON STARTS UP RIGHT AWAY WHEN I PULL AWAY FROM THE DOCK AT LOW RPM SHE CUTS RIGHT OUT<br />I START HER RIGHT UP AGAIN AND HAVE TO PUSH THE TROTTLE FULLY FOWARD TO GET GOING THEN BACK DOWN<br />TO A SAFE SPEED AND SHE WILL RUN FINE IF I POWER<br />DOWN TO A LOW RPM SHE WILL CUT OUT I CHANGED THE<br />PLUGS, FILTERS, ADDED 2X4 FUEL TREATMENT. CHANGED<br />PRIMER BALL NO CHANGE THE MOTOR IS STILL UNDER<br />WARRENTY BUT I WOULD HAVE TO PULL THE BOAT OUT OF<br />THE SLIP AND TOW HER 40 MILES TO THE DEALER IF<br />THIS IS A SIMPLE FIX PLEASE HELP<br /><br />THANKS IN ADVANCE<br /><br />GEORGE V
