got stranded today; Went to start up to go home, it stopped like the battery was nearly dead. Basically, after turning off ignition and removing the key, the starter was still trying to engage. Couldn't get the trim to pull the motor up or get any tones/lights from the ignition. It was just like current was stuck going to the starter, but not enough to turn it over. Initially I thought starter, but for it to happen with the ignition killed, makes me think a faulty ignition switch/wire or my real guess is starter solenoid.<br /><br />Funny thing is, after I paddled and got towed back to the dock, for kicks I re-connected the battery, and things were working fine again. Of course now the battery was nearly drained from the starter getting 'stuck'. Had enough juice to get the motor tilted up though so I could get the boat back on the trailer. Ignition tones and lights worked fine, and starter seemed to work fine as well, but the battery was now too low for it to turn over...<br /><br />Any thoughts?
