David 1000
- Jul 3, 2005
- 7
gas and oil mixture thank for any help
Originally posted by Paul Moir:<br /> 24:1 wouln't hurt it - it really makes no difference. If it's got no top speed I would first look at whether the carb was adjusted correctly, second have a look at the fuel supply (pump primer bulb while it's running bad and see if it helps/harms), third look to see if you're loosing spark on one cylinder. Pull a lead and see how it runs on one cylinder to find out that.
