  #1
Old September 8th, 2005, 11:40 AM
gevans gevans is offline
Default 1989 Evinrude V4 120 hp power loss at wot
I'm new to iboat, and new to boating in general.After reading 15 pages of forums, I have to ask for your assistance. I purchased a Stratos 284 bass boat with an 1989 Evinrude V4 120hp engine.Model# E120TLCEM Serial#333686 I went out to test it this weekend and it ran like a champ at full throttle for about 8-9 minutes and then just cut out. I restarted it and it stalled again. Thinking it was an overheat condition, I threw the trolling motor in and headed back to the launch. After 40 min. of trolling, the batts. went dead. I restarted the engine and it ran fine back to the launch ramp approx a mile away. It's been trailered since, because I'm not sure what caused it. I'm thinking about taking it to a dealer for tune up, but after reading your forums, I believe there are a few things I can look at myself, with your guidance. Such as spark gaps, cracked coils, fuel filter, plug wires ect... Love your ideas and tricks to try in the forum section. I don't feel so much like a dummy when I read your advice. Any suggestions you have are important information to me. Thanks in advance gents...
  #2
Old September 8th, 2005, 01:17 PM
JB's Avatar
JB JB is offline
Default Re: 1989 Evinrude V4 120 hp power loss at wot
Evinrude Trouble
__________________
RED SKY at night. . .
JB
  #3
Old September 8th, 2005, 01:41 PM
Walker Walker is offline
The first thing you have to determine is was it overheating or not. Does you alarm system work and are your temp sensors functioning properly. Next, did your motor quit from lack of spark or a fuel problem. You need to make it do it again and then test for spark immediately. Bad Powerpacks sometimes work fine until they get warm. Sometimes you can test them for this problem by running your engine on muffs and heating up the powerpack with a hair dryer.
  #4
Old September 8th, 2005, 07:15 PM
Quote:
Originally posted by Walker: The first thing you have to determine is was it overheating or not. Does you alarm system work and are your temp sensors functioning properly. Next, did your motor quit from lack of spark or a fuel problem. You need to make it do it again and then test for spark immediately. Bad Powerpacks sometimes work fine until they get warm. Sometimes you can test them for this problem by running your engine on muffs and heating up the powerpack with a hair dryer.
  #5
Old September 8th, 2005, 07:22 PM
Walker, thanks for the reply. My boating friend asked me to look at the plugs right away, and when I did they were fouled with carbon build-up.I replaced them with new ones just today, and gapped them properly. Took the boat over to the lake, and it ran like a top for an hour straight.Not one problem! But I'm not sure that everything is back to normal until I run it again.Do you think that this might have corrected the problem, or might it be something still?It just seemed to easy a fix.....Thanks Again!!
  #6
Old September 8th, 2005, 07:36 PM
djzyla1980 djzyla1980 is offline
Fouling plugs could have caused your problem... Do you know the history on this motor. When the impellor was replaced last, If it has been decarbed?If you are unsure of these then I would suggest doing that at the least.I figured out in a short period that there are 3 types of problems:1- you spend hours on end looking for a problem that seems to be no fix2-you waste much time and effort into finding the problem and it's an easy fix right in front of your face.or you get lucky and3-you try one of the least time and $ consumption item(s) and it works Maybe you rolled the dice and won... sometimes it sounds to easy to be true-but the only way to tell is to run it!! If you still have problems with fouling plugs... I would test spark/compression and if all looks good check out the carbs next. Might be time for a carb clean and rebuild.
  #7
Old September 8th, 2005, 08:34 PM
If the new plugs do the same thing then I'd check idle timing and all the recirculation valves for proper operation.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1989 Evinrude V4 120 hp power loss at wot gevans Non-Repair Outboard Discussions 1 September 8th, 2005 01:17 PM
1989 johnson 60hp loss of power . mark.aa Johnson & Evinrude Outboards 3 August 23rd, 2005 12:21 AM
1989 Yamaha 70 hp Power loss after warm up Dave Butterworth Yamaha & Suzuki Outboards 1 July 4th, 2005 08:28 AM
1989 Evinrude 120 intermittant miss and power loss polzsc Johnson & Evinrude Outboards 2 March 29th, 2003 06:54 AM
1989 Suzuki DT85 Loss of power Timo-MA Yamaha & Suzuki Outboards 3 July 3rd, 2002 02:37 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
