seafoam ( deep creep ) ??
slamer12
I put that seafoam stuff in the carb's tonight and let it sit for 1/2 hour and then started the boat up and it seem to have made the symtoms worse than before any ideas on how long it takes to burn this stuff out everybody seem to rave about this stuff ???? . Should i pull the plugs to see if anything got loose and got into the cylinders ??
bubbakat
Re: seafoam ( deep creep ) ??
I always change my plugs after a decarb or at least clean them. Then take it to the water an run it like you stole it to blow all the loose carbon out.
slamer12
bubba is it normal that the carb will run choopy after you add the seafoam for a while ??
wayne h
Master Chief Petty Officer
u really have to run it wide open changing the throttle for atleast 20-30 mins to really blow her out then put new plugs in. i always decarb right before i head to the lake then like started above run her like your stole her
Marauderk
Run the boat with seafoam in the tank about one bottle to a gallon of premix. take her out on the water and run her wide open for the whole gallon. it will smoke alot but clean it all up
