My 1984 Johnson 90hp VRO4. I have rebuilt carbs. Replaced fuel pump. Have cleaned out fuel tank. Sometiumes it will get where it will start to die out whem you are throttled up an sometimes it will not idle properly. If you pump up the primer bulb it will start to run properly. Yesterday I used about a half of tank of fuel. Then toped off fuel tank, It ran about 1/4 of tis tank full and started to act up.I pumped up on primer bulb and it started to run OK, until was going to load back on trailer and then it didn't want to Idle properly. The engines compression is 110lbs on all four cylinders.
