Align the flywheel key with the fiber rubbing portion of the points, then set the points so that a .020 feeler gauge will pass thru the gap but a .022 will not.
If you're saying that the engine wants to dies out when throttle is applied, that's usually due to a fouled and/or improperly adjusted carburetor.
