Hello, I have an Evinrude 40 hp outboard motor and it seems as one of the coils will not fuction but both have been replaced. <br />The idle is poor and throttle up doesn't want to idle on power up either.<br />Motor runs good when out of water, but has lack of power when in the lake.<br />The motor is an older Motor back in 69 but has been running so well up until last year. I started it this year which took right off, but I don't know if the problems I'm having are large or small to fix. I ran a circuit tester and everything shows its fine, but when under pressure it won't throttle up to speed. Can you please give me advice on what you think the problem is.
