"1980 Evinrude 90 H.P. Power Trim and Tilt problem
jfm815
Presently the engine is in the down position and when activating the trim and tilt switch the trim and tilt motor works, however, the pins do not come out of their cylinders and the motor will not raise. How does one manually raise this motor.<br />Is there a release bolt that I can get at with the engine down so I can check the trim and tilt fluid level.
Flash Wax Man
Re: "1980 Evinrude 90 H.P. Power Trim and Tilt problem
Hello, there is a manual relief valve that is on the lower right side of the motor, inside a hole that has a slotted head for a flat screw driver. Unscrew it until the pressure releases and you see trim oil leaking out.
