98 Johnson 115 - Oil Leak - Recirculation Problem - Idle
surfsailormd
At idle speeds this motor leaks major oil. I believe the problem is with the oil recirculation / system<br /><br />took it to a johnson dealer and all they did was to zip tie around the spot where the oil goes back into the engine.<br /><br />I would have to bet that this problem existed for more than just this motor as it has done this from day 1 .....<br /><br />Anyone have similar problems / or is there recall / fix for this problem.<br /><br />Thanks in advance
