Hi guys I could use some help.<br />I HAVE A 15FT INVADER runabouht with a 35 hp evinrude short shaft.<br />any way it has a "20 transom so I built a bracket to lower the enigne.<br />It worked great with my 25hp and I took it on 2 runs wth the 35 and it worked great.<br />and now the problem the last time I ted to launch it the rear sat so low that the pee hole was under water <br />The only thing I chganed was to put on my 5hp kicker insted of the 3hp it had on it.<br />the baot had a tip to it the bow was higher than normal.<br />the first thing I did was to make sure I wasn't takeing on water I wasn't<br />I tred it twice and got the same results <br />I don't get it I ran it twice befgor with no problems I did also add some trim tabs would that make a difence?<br />any help would be great.<br /> http://www.picturetrail.com/gallery/view?p=999&gid=7331589&uid=2461186&members=1 <br />this pic is without the new tabs and the 5hp kicker
