I'd never before used my livewell. Motor was burned out and I'm not a big fisherman so its not something I used before. So here's my knuclehead question. Is the water pump simply to fill the livewell and should then be turned off? Or is it left on to circulate? Reason I'm asking is I also filled my bildge up with seawater and I suspect the water pump was the cause. I think you can suspect it's kind of embarrasing when you pull your plug and it takes around 10 minutes to drain your bildge.
