Re: From fresh to salt water
Just a good Flushing after each use...and make sure you run it long enough for the t-stats to open up. That guarantees the entire system will get flushed.<br /><br />Something additional you might want to do is to stop along the way home at a freshwater lake. Launch the boat and run it for a few minutes. This will do 2 things...1) it will submerge the trailer and get any remaining salt off. 2) it will allow the engine to clean its cooling system with fresh water. Running on the muffs is OK, but its not the same as running in a body of water.<br /><br />Beezee28's right, the Marine patrol is very busy doing safety checks as well as fishing license/catch limit checks. IF you get caught, it wont be cheap!<br />Nav
