Re: adjusting motor height
Props are generally labeled with 2 numbers(10/13 for example)The first is the diameter,the second is the pitch.You will need to determine what pitch yours is.You will also need to get a reliable tach as it sounds like yours is broken(or might not be setup right)<br /> As far as the bow pulling down,do you mean porpoising?(bouncing up-n-down).When the motor/trim is tucked in(down)this can cause down force on the bow.When running wide open,you should be trimmed out to where the AV(anti-ventilation plate,just above the prop) is parallel with water surface. <br /> Where is the AV plate at in relation to the bottom of the keel/hull?It should be level with it or a little above it(this term is known as X-dimension,do a search)
