I have two intermitten problem electrical problem and am not sure if they are related or the correct way to fix them.<br />1. Sometimes when I turn off my motor, than when I turn the key to restart the engine nothing happens (no power), but I can wiggle the big red multi-connector inside the motor case and I will get power and start the engine. I checked my big red multiconnector under the motor cover and found it fairly oxidized and have tried to clean it, but feel that maybe some of the wires maybe old and corroded that are not visible. It looks like a pretty intense trouble shooting job and thought that maybe I should just replace the whole wiring harness? Where is the best place to get a harness?<br />2. This problem was addressed before, but I have not resolved it so here it is again. I turn off my motor, and then try and restart it, some times the starter runs normal, other times it acts like it is not getting enough voltage & gets very hot. I checked the battery before starting and have 12.5 volts at the top of the selinoid, I checked the voltage at the top of the selinoid, while attempting to crank the engine and got 10.5 volts. I have a new 100 amp battery, and a second 100 amp battery which I jumped and still got the same voltage of 10.5. Last time I had to rap a cord around the flywheel (assist the starter) and pull start it while some turned the starter key. I initially thought it might be the ground so I ran the jumper cable from the battery ground to the starter ground but still got the same results. Anyone got any ideas on what trouble shooting I need to do or could this be related to Problem #1? I have spent allot of time cleaning all the other wire connections and also ran a second ground from where the battery grounds to the motor directly to the starter mounting bolts.
