88' Johnson 120, No spark-no start-no idea
scg
I have a 1988 Johnson 120 (J120TLCCA)that did run ok untill now. The test that I have done has lead to three things.<br />1-powerpack part#0583489<br />2-stator part#0583410<br />3-timer base & sensor part#0583508<br /><br />All coils have a spark (some what) on the first rotation, then nothing. Only one coil has any spark at every rotation. This spark is very small and only about 1/8 too 1/16 of an inch from the plug wire to ground. I checked all with all plugs removed.<br /><br />How can I test the three parts listed above or should I buy a service manual? <br />I though I would try this site first because experience seem to beat any book.<br /><br />Thanks<br />scg
Walker
Re: 88' Johnson 120, No spark-no start-no idea
Do you have a strong battery and is it spinning the starter/motor fast enough.
scg
Yes, I have a new/strong battery. I have disconnected the black/yellow wire from the powerpack that disabled the kill switch. Still no change in the spark.
scg
Porblem Fixed.......<br />The connector at the coils from the power pack were corroded 3 out of 4. With new connectors, this motor is running at 100%......<br /><br />To everyone, check all connections on anything before replacing any parts.
