Originally posted by walleyehed:<br /> Welcome, Gator!<br />What do you get when you open it clear up????<br />Is the max advance timing arm moving fwd??? make sure the arm is moving fwd when you advance the throttle...it should begin to move just slightly before the throttle plates start to open.<br />Have you done a compression check on this yet???
