When operating at WOT for 2-3 minutes, the engine starts to lunge and jerk and subsequently slow down to a crawl. If I throttle back then try to go again the problem persists. However, if I turn the engine completly off and then start it won't occur again for 2 - 3 minutes. Also if I run at 4000 RMPs or less this problem does not occur. I have emptied the fuel, replaced it with premium grade and added Sea Foam injection cleaner, but the problem still persists and occurs only if I run at greater than 4000 RPMs. I've tried a few other things like looking for kinks in fuel line, air intake, etc but no luck. Any help or thoughts?
