  #1
Old August 14th, 2005, 07:28 PM
jackman1939 jackman1939 is offline
Default Evinrude 1997 FICHT engine - blew small hole in crankcase
I bought this engine new in 1998. It has always run very good. I use 7712 plugs and after reading the indexing information, I always index the plugs. The #3 plug always seems to be grossly fouled after only 2 trips (30 miles each). I clean it and reinstall it. The engine usually tacks out at about 4300 rpm. I have a 1996 OMC Neptune center console boat. The prop is a 14 1/4 X 21. The boat usually has a max speed of 44 mph. The last 2 times I went out, I noticed the top speed was only 39 mph. Ran fine though. Went out Saturday and decided to come in early because of a big storm approaching. Was tooling along at top speed for about 10 minutes, when all of a sudden, the engine made a loud noise and started running very sputterly. Saw a little smoke coming out from the cover. Turned the engine off, took the cover off - it looked ok. Started right up, but sounded terrible. Shut it down and called Sea Tow. When I got home, I took the cover off and removed all the plugs (they all looked ok). Put my finger over the spark plug hole and had my wife crank the engine – all cylinders had compression and suction. Upon further inspection, I noticed a few pea sized pieces of metal laying inside. Spotted a hole in the crankcase, between cylinders 2 and 4.Hooked up my laptop, connected the test wire from the engine to the serial port and ran the OMC diagnostic software. It came up with 1 error code: "Intermittent 35 - oil pressure switch malfunction. Oil pressure switch is not opening or the switch harness lead is grounded".I got not indication on the OMC instrument cluster of any oil problem. Checked the oil reservoir and it was 3/4 full. Pulled the rubber line off the metal line where the oil comes into the engine. Hooked up a piece of clear tubing to the metal line and sucked on it - oil was present there.SOOOoooo, I am getting ready to tear the engine apart and try to fix it.About 4 years ago, the oil light and beep came on every now and then. I replaced the oil pump and that fixed the problem.Any tips you can give me would be appreciated. I am not an outboard engine mechanic, I just am pretty good at fixing stuff.thanks,Jack
  #2
Old August 14th, 2005, 07:35 PM
Default Re: Evinrude 1997 FICHT engine - blew small hole in crankcase
My engine is a 150hp.
  #3
Old August 14th, 2005, 08:52 PM
seahorse5 seahorse5 is offline
Chances are the damaged rod and broken crankcase were due to overpropping the motor and causing it to "lug" itself to death.That motor should have been propped for 5300-5500 rpm which would have been at least a 17" pitch prop, not a 21" turning only 4300 rpm.It is not economically feasable to rebuild your motor as the '97 and '98 versions have next to no trade in value when they are in good running shape.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1997 150 Ficht water sensor - check engine burakv Johnson & Evinrude Outboards 2 May 17th, 2009 04:33 AM
200 Evinrude 225 Ficht Blew Up - Bang! doug brander Johnson & Evinrude Outboards 6 July 12th, 2006 11:54 PM
Small crack / hole on lower engine ? Danny_P_G Johnson & Evinrude Outboards 1 June 11th, 2006 04:38 AM
EVINRUDE FICHT 150 Broken Crankcase Main Bolts Aldo Bax Johnson & Evinrude Outboards 18 June 29th, 2005 03:43 AM
1997 Evinrude 150 FICHT large_arge Johnson & Evinrude Outboards 8 February 25th, 2004 06:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
