78 175 EVINRUDE IDLE ADJUSTMENT
YZF195
ANY KNOW HOW TO SPEED THE IDLE UP ON A 1978 EVINRUDE 175 AND WHAT SHOULD THE PROPER IDLE SPEED BE? THANKS KEITH
OBJ
Re: 78 175 EVINRUDE IDLE ADJUSTMENT
Hi Keith, welcome to iboats!<br /><br />I believe it should be somewhere around 650 in gear and 900 in neutral Keith. There is a idle adjust screw on the spark advance lever on the engine. But using this may mask a problem. Can you tell us about what's happening with the engine, new problem or old one? Do you have a service manual?<br /><br />Thanks.
