BassCaster77
- Jun 13, 2005
- 2
I recently put a 1990 25hp Johnson on my boat and need advice on a problem I'm having with it. The motor will run fine for a minute or so then it will almost die, then rev up again. It does this repeatedly until it finally dies completely. The only way to keep it running is if my buddy pumps the primer bulb while we're moving. I changed the primer bulb and that didn't seem to help.Do you guys think this is a problem in the motor itself such as the fuel pump or could it be an air leak somewhere in the fuel lines or tank? Any suggestions?
