Old Johnson SeaHorse
Vintage46
I need help finding a "water pump" for this old motor. Near as I can tell, it is a model HD-25 with a serial number of 006841. These numbers are stamped into a pad on what I would call the engine block and are kind of smeary looking. Would like to know year of manufacture if possible. Thanks in advance for any and all help.
Paul Moir
Re: Old Johnson SeaHorse
Welcome to Iboats, Vintage46!<br /><br />The "water pump" is hiding behind the propeller. It's not like a normal one and doesn't need regular service. But if it's not working, I've got some leads for reproduction parts.<br />The HD-25 (2.5hp) was made between '46 and '50, but that serial number doesn't jive with the ones used during those years. Can you double-check it - especially the leading 0. It ought to be 6 digits long like you've got.
JB
Paul, <br /><br />What a priceless asset you are to this board!<br /><br />I am blown away by the thoroughness and the amount of information in your posts, and the skill with which you present it.<br /><br />Thank you very much for being here and for your consistently helpful posts.<br /><br />I salute you, Sir. :)
Paul Moir
Wow, thank you JB and REELSPORT! A really appreciate it. :)
fire831
Paul has helped me more than once also. Very knowledgable,and if he don't know he can probably tell you who to get with that does. Thanks Paul. Rodger
