Boilermaker
- Sep 28, 2003
- 388
I was trying to do a link & sync on my Johnson 115 (115ETL78C) When I shifted the throttle forward with the engine off, the shifter seems to jump a tooth in the nylon gear(in the controller) and now will not go into reverse. This has happened once or twice before and required the disassembly and realignment of the shifter control.<br /><br />Is this normal??? It works fine as long as you don't try and shift it without the engine running. It looks like their may be a tooth missing from the nylon "gear". Are replacment parts available for the shifter??? OR replacement shift controllers available?<br />ANY IDEAS HEAR???<br />Thanks
