sorry hit wrong key, iwould turn off key and engine would idle after 30 to 90 seconds would stall out. when key was turned off all guages shut down. also sometimes it would shut corectly other times no. i had omc tuner and tried it in case of carbon build up, got minimal heavy exhaust. after twelve proper shut offs started again. i then replaced with omc original switch which is set up for safety lanyard which i don't have started engine and it continued to run, i tried several more times and it shut off properly. engine is 96 evinrude 150 carb.with vro, engine appeared to have low hours. also changed plugs after tuner. thanks
