The flywheel on my "64 40hp evinrude hits the coils. I noticed that the breaker plate was a bit loose.I adjusted the coils in farther to increase the clearance. It ran for about 5 minutes and sheared another key. Can the breaker plate being loose shear the flywheel key? I ordered a new plastic wear ring that fits between the plate and the retaining/advance plate. Will this correct the problem??<br />Thanks
