Hi everyone. I have a 1989 28 HP Evinrude. The problem is when I leave the No Wake Zone and start to increase speed, the motor will run fine for just a few seconds then bog down and only idle. Pumping the bulb does not help.<br />I have replaced the fuel line set and have tried another fuel tank but the same results.<br />The next step would be to rebuild the fuel pump?<br />Carb? Thanks
