A few years ago I purchased an Evinrude Yachtwin 4 from an ad in the local paper and ran it for two years without any trouble or any maintenance (including changing the plugs). What the heck, I figured, it's a sailboat. I didn't motor very much at all.<br /><br />Then I got off the water for a few years. Fast foward...<br /><br />The motor has some issues and needs maintenance; but I can not figure out the model number or year. There is no data plate that I can find. Removing the cover I found a couple of tags. One is round and set into the motor. It reads....<br /><br />B<br />1377528<br /><br />The other is a rectangular tag which is attached with a metal strip. It Reads....<br /><br />I6 E L<br /> MX<br />396512<br /><br />There are various other molded numbers inside; but I'm pretty sure those are the individual part numbers to the components. Any help?<br /><br />The motor appears to have been designed to have a plastic fuel tank strapped to the side, although I've been using a regular red external tank.<br /><br />Adam
