reeldutch
- Feb 2, 2004
- 1,340
The outboard is a 1974 50 evinrude<br />and the top piston is not producing power.<br />first i thought it was gas related so i sprayed some mixture into the carbs troath the top carb and no change at all.<br />i sprayed some into the bottem one and the motor almost stalls out.<br />then i pulled the ignition wire on the top cylinder and no change if i pull the bottem one moter doesnt run at all.<br />then i checked for spark and the top plug has weak spark.<br /><br />now how can i figure out if its a bad pp or coil<br /><br />thanks reeldutch
