I am changing the gearcase oil on a 1982 evinrude 70hp and need some advice on the bottom (drain) seal. The old plug has an 'O' ring which sits neatly in an indentation at the head end of the plug. I went to buy a new one at the evinrude dealer and he came up with the same nylon washer for both the fill/drain plug and the higher oil level plug.<br /> <br />The 'O' ring looks like it might fit as standard but maybe the previous owner replaced the original nylon washer with an 'O' ring? Can someone confirm what the seal should be on this engine? <br /><br />If anything, I would guess that the 'O' ring would provide a better seal than a nylon washer?<br /><br />Appreciate your guidance.<br /><br />Dave
