I know little about boat motors but can fix anything if given good instructions. I was running my brother-in-law's boat the other day in a marsh. The engine started sputtering and then stopped. I figured the water intake had gotten clogged and it overheated. I got a tow in then cleaned out the clogged intakes and let it cool down. Next morning, the engine worked fine but I could tilt the motor up or down at all. I know I didn't run aground in any way that might have damaged the lift mechanism, but it did stop working when the engine overheated. I cannot lift it manually, it's stuck in the down position. I can't pull it out of the water to work on it (the engine will drag if I trailer it). I can hear the relays clicking to actuate the tilt lift when I try but there is no other noise, like a hydraulic pump. I checked both sides of the relay lines and there is good voltage across all terminals. Any Ideas of any sort would be appreciated!! This is a Evinrude 88HP SPL. 1996 Model #: XE88TSLEDR Serial G04174969 --- Please help, Thanks, boatstupid
