Need info on Johnson Model FD-16A
jeffrobshaw
Hello,<br /><br />Looking for:<br />Year of manufacture:<br />Horsepower:<br />Oil/fuel mixture:<br /><br />for old Johnson outboard before putting her back in the water....<br /><br />Model: FD-16A<br />Serial: 2217222<br /><br />Any help would be greatly appreciated!<br /><br />Jeff
Paul Moir
Re: Need info on Johnson Model FD-16A
Welcome to Iboats JeffR!<br /><br />Sounds like a fun project. Here's your info:<br />Year: 1962<br />HP: 18hp<br />Fuel/Oil mix: 24:1 87 octane gas to TC-W3 rated outboard oil.<br /><br />A little extra info:<br /><br />Spark plugs: Champion J4C (replacing J4J) gapped at .030"<br />Lower unit lube: OMC/BRP 'HiVis' or other brand 90 weight outboard gearcase lube.<br /><br />If it's been a while since she's been fired, put a teaspoon of TC-W3 in each cylinder and turn it over a few times to spread it around. You'll have to replace the water pump impeller straight away as they go bad just sitting around. Fortunately, they're cheap and readily available, and replacing it is a DIY project. The only special tool you need is a service manual.
jeffrobshaw
Originally posted by Paul Moir:<br /> Welcome to Iboats JeffR!<br /><br />Sounds like a fun project. Here's your info:<br />Year: 1962<br />HP: 18hp<br />Fuel/Oil mix: 24:1 87 octane gas to TC-W3 rated outboard oil.<br /><br />A little extra info:<br /><br />Spark plugs: Champion J4C (replacing J4J) gapped at .030"<br />Lower unit lube: OMC/BRP 'HiVis' or other brand 90 weight outboard gearcase lube.<br /><br />If it's been a while since she's been fired, put a teaspoon of TC-W3 in each cylinder and turn it over a few times to spread it around. You'll have to replace the water pump impeller straight away as they go bad just sitting around. Fortunately, they're cheap and readily available, and replacing it is a DIY project. The only special tool you need is a service manual.
Thanks, Paul! I'm looking forward to getting her running again. Thanks again for the quick reply and the extra info!<br /><br />Jeff
