O/B races then stalls while attempting slow idle
Seawint
My Johnson 9.9 Outboard Motor Model J10SELE fails to idle slowly. With throttle set low the motor races to excessive rpm, then stalls out. It appears fuel-starved. What are likely causes? Are there diagnostic tests I could try. The symptom resembles motor behavior after fuel line is disconnected.
