starcraftsinking
- Feb 2, 2004
- 2
Hello, I have a 86'Johnson Evinrudee 28spl. The motor runs great. With execption that occasionally the motor does not shut off. I've replaced the iginition switch / plug / and checked for bad faulty connections. The only way to shut if off is to pull the fuel line because even the kill switch didnt work. Although after I replaced the ignition switch the engine still didnt shut off when I turned the key but it did shut off after I pulled the kill switch. Anyone have any ideas?
