First post - thanks in advance!<br /><br />I bought this motor last year. It started and idled very nicely on the trailer with the muffs on.<br /><br />The first day we ran it for about 3 hours and it ran just great at all speeds. Right near the end of the day the motor stalled suddenly, but it restarted.<br /><br />The next time out it ran for about 10 minuted before it cut out.<br /><br />When it cuts out it stops suddenly, no warning whatsoever. After it stops, the flywheel will not turn, the motor appears to be jammed tight. After a few minutes the starter motor has enough strength to budge it just a bit.<br /><br />The next day it starts fine again and runs great for about 10 minutes. Then the same thing happened.<br /><br />I am suspecting cooling problems, thinking hte engine may be overheating. I have started to change out the impeler and the therostats although they both appear to be in perfect condition (hence this post). Also, I have read in some posts that there is a overheat warning horn? I have not heard anything like that.<br /><br />Does this condition sound familiar to anyone?<br /><br />Thanks.
