  #1
Old July 23rd, 2005, 07:42 AM
Gerard Ranft Gerard Ranft is offline
Default Evinrude 5PK stalls after a minute or so
posted July 23, 2005 10:29 AM --------------------------------------------------------------------------------Hey guys, A problem from the netherlands. I have an Evinrude from 1965 motornumber: 5502S B1761.When i start it it runs, but dies shorly after. The carburator is rebuild today with all new components and is very clean and all channels are open including the jets and under the small lid on top of the carburator. I have read a lot of posts now but the carburator seems fine, altough it seems to be leaking a bit from the input mouth, but is should not do this because of the rebuild of the carb and tye correct float level. Now i im a bit at a loss!! Furter information:When the engine stalls first one of the cylinders stops working and the plugs look a little wet. Is the a way to see if the pressure of the fuel pump is too high? I cannot explain the floating of the carb. I must admit that the old cork floater is still used, but i cannot find another here in the netherlands. how can i check the float level in a working machine?Someone has drilled holes in the glassfiber cover for the same reason?? There seems to be no air filter, no air input and no fuel filter?? Yes,i know, a lot of questions, but otherwise i would try to solve this myself, but i'm not an expert in outboard (yet). Please, any input is welcome because the summer is getting smaller... Greetings to all of you,Gerard Ranft.Holland.
  #2
Old July 23rd, 2005, 08:19 AM
Joey One Joey One is offline
Default Re: Evinrude 5PK stalls after a minute or so
I can't pinpoint your problem from the information you listed. However, a 40 year old cork float is not very reliable. If you can't get a new metal or plastic float, somehow thoroughly dry the cork float and coat it thoroughly with epoxy. Then go to "SEARCH" in this forum and request "adjusting float".
  #3
Old July 23rd, 2005, 08:31 AM
Thanks Joey.Will do that and we'll see from there.
  #4
Old July 28th, 2005, 11:33 AM
Well gentlemen, i've repaired the float by drying it and seal it with PVC glue and measured the float level. The fuellevel is about half the height of the floaterbowl.De motor keeps running BUT much smokes and it sounds too rich to me. sometimes running one one cylinder as well. what should i do next? it still runs VERY bad and does not reach any high rpm.... it still does not run on stationair rpm though the carb IS clean.Any things i've forgot? Thanks in advance for some solid advice.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercruiser 5.0 stalls after about 1 minute hirschaj Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 April 28th, 2009 01:48 PM
Was Running a minute ago? 11craigt Johnson & Evinrude Outboards 8 November 6th, 2006 09:03 PM
850 bogs down after i minute yes90125 Mercury & Mariner Outboards 3 August 31st, 2003 10:36 AM
Off the Subject for one Minute Pro Crappie Guide Non-Repair Outboard Discussions 1 May 19th, 2002 01:49 PM
Pints Per Minute? Richard R Non-Repair Outboard Discussions 5 September 28th, 2001 11:51 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
