It is a 2-stroke with carb.<br /><br />When starting upp this motor after the winter the SLOW-system was aktivaited after 10 minutes or so. The question is then if the sensor is broken of if it's cooling bad?<br /><br />I have disconnected the sensor and then the motor is working fine. I have mesuared the watertemperature to about 155 F at idle forward. At WOT the watertemperature is only about 100 F.<br /><br />Does anyone know if the cooling is working proporly on this unit based on the facts above?<br /><br />Thanks!<br />/Emil
